Rebuilt and sort of re-engineered Dirty Hands Splitter
Howdy all, I have a Dirty Hands log splitter. Bought it new a long, long time ago. Engine crapped out, got a new one from Harbor Freight, that crapped out just recently.
As such, we replaced the engine with a 22hp and a 28 gpm pump that we had. We blew up the 22-ton cylinder (4x1.75x24) likely caused by way to much heat in the system and upgraded to a much larger 5x2x24. We scavenged up a 25-gallon tank to deal with any heat issues (I love free stuff) and plumbed it in.
I was planning on running AW32, AW46 or even AW68 here in CT, we only split in the spring, summer and fall. So generally, temperatures are always over 32 F when being used.
Heat and longevity are my concerns. My tank has a strainer filter and a hydraulic oil filter (spin on).
Eventually, I will build a more perfect commercial duty splitter, however, that time isn't now. I would like to understand the answers to the following questions, so I know how to proceed now, and in the future.
My questions are as follows:
1. Is AW32 or AW46 the best all-around option? I was also considering AW68 any thoughts?
2. Is there any real difference between the three in this application is there enough of a difference to make a difference?
3. What oil brand would you recommend -- or again, does it really not matter in this application?
4. My primary concern is heat build-up in the fluid and cylinder-- as this unit was getting very hot when used heavily-- hence we scrounged up a large tank. Which oil would help best with heat build-up?
5. What is the best place to get the best price on 5 gal. pails of whatever oil is recommended?
Thank you for taking the time to review. I was unable to get clear answers from searching in here to these questions.
Don
Given that you're not operating in winter, I'd say the AW46 is fine.
Often new units come with instructions which say AW fluids or ATF are acceptable.
Brand won't matter; it's a simply hydraulic system.
You're overthinking it. Just pick one and it'll be fine.
If you have a farm supply store near you, that's often a good source for reasonable pricing.
Wow are you a commercial operation? That's a lot of wood to split!
I think the larger tank will help slow the heat build-up, but once hot, you may have the same issue. Any chance you could rig a hydraulic cooler to this? Maybe something plumbed back into the return line scavenged from an old excavator or wheel loader?
I might add that 28gpm is a LOT of flow for a log splitter. There's no need for a splitter ram to have to operate that fast. And so some (most?) of the heat is possibly coming from such a high volume being forced through controls (directional valve) not rated for such flow rates.
You might do well to add in a proportioning valve which dumps off excess flow.
No, I'm not commercial but I have acres of dead ash trees and logs to split. And the splitter runs pretty much all day and day after until the rounds are done.
I know the large tank will help, the oil will cool much better than the clownishly small 5-7 gallon axle tank. Until I build the new splitter, there will likely not be any practical way to run an oil cooler. (It's also likely to get destroyed/damaged being used in the woods). It's possible, but I'll have to look around at what kinda junk I can scavenge off.
I'm not planning on the new build until at least next year.
Thanks,
Don
That's a great idea; can you show me a link to such a valve?
Thank you,
Don
Thank you, that was the direction I was leaning in.
Seems the majority of the heat is simply from the flow. My full size 1968 John Deere 3020D tractor is 18GPM hydraulic flow and EVERYTHING on it is hydraulic to include the steering and brakes. No way that a log splitter needs 28GPM...so the excess flow just becomes heat.
I would say the best approach would be to find a local or regional hydraulic shop in your area. Tell them (or show them pics) of what you have and ask for their recommendation for a specific product.
I know this is important because I have a friend who has a very large tree chipper (12" capacity). It has a 3' diameter flywheel with cutting edges, driven by the PTO. But, the infeed motor system is run via the tractor hydraulics. He had to add a proportional valve to bleed off some of the flow; it was over-powering the hydraulic feed motor on the side of the unit and getting HOT. Once we got the flow set right, the temps dropped and all worked fine.
The 28 GPM pump on this log splitter is a 2 stage, 28 GPM high flow (low pressure) and 7 GPM low flow (high pressure).
Don
Yeah, like I said if you got a link to a product, I'd be interested to read it. But yeah, I didn't know the controls had a flow rating and I'm going to look into this right now.
Thanks,
Don
How did this work out for you?
Aluminum fuel tank would make for some additional cooling.
I think many missed the dual stage pump and thought it was a straight 28 gpm.
The bigger the tank, the less surface area for volume. Surface area cools the oil. However, the bigger tank gives you more residence time in which heat can dissipate. Somewhere you will find an optimum size. To help: use an aluminum tank and put cooling fins on it. Put a cooler in line with the oil flow. Use a lower viscosity oil which may generate less heat in the pumping process.
I'd probably run iso68 fluid if you arent seeing cold temps..
and running for hours in the summer... best for heavy duty use profile.
ISO 46 for normal use
I do wonder if your equipment is well matched.
my 225cc (8hp?) has a 2 stage pump with 14gpm on high volume and a 27?ton ram.
it gets hot enough to burn you. has about 15s cycle time.
Seems like that pump would be a better fit on something with a huge ram that needs more oil volume.
a 40ton ? and the motor is generously sized but that shouldnt make much difference its more about the rpm.
Edit: Champion 40ton model is 338cc and 24gpm pump.
also 25gal is probably overkill and alot of fluid to haul around.. it wont have much cooling either.
Your tank should be 2-3 times your flow rate as a starting point for heat. 28 gpm is going to generate a lot of excessive heat because it it doing a lot of excess work flowing all that oil through the bypass at pressure. You could add a cooler. Eventually you’ll cook all the seals in the system.
We use ISO 46 in all of our equipment, including log splitter-like duties.
If this were a “make an awesome log splitter at any cost” project an accumulator with a low volume pump would be the setup. High flow rate when needed, recharges when on standby, doesn’t generate a lot of heat due to excessive flow.
Don
In answer to Q1 the pump manufacturer usually specifies the preferred viscosity.
As far as seal failure, you may have such a high pressure in the system that the seals are blowing out.
