Originally Posted By: DoubleWasp
Originally Posted By: c502cid
Originally Posted By: leroyd92
Thank you for clearing that up for me I'm not am engine builder.
My friend just told me he typically used 1qt every 4500 miles. So it seems like the motor is happy with. 15w40
Either your friend is fibbing or I want the name of that engine builder! A big block that uses 1 qt every 4500 miles!
It's possible. A lot of the marine big blocks we do go 100 hours of a lot of high rpm operations, and we get out as much oil as we put in in the first place.
On-topic:
Those who are saying thick oil for the valvetrain are correct. BBC valvetrains are not exactly happy with constant high rpms, and a motorhome will give you exactly that. Consider 15w-40 your minimum. I'd run a 20-50 if it were me.
Using VR1 and Schaeffer 20-50, we've been regularly beating the wear universal averages while running the oil twice as long as the universal averages.
Curious.... I have a 94 Fleetwood Southwind Storm with a Chevy 454 TBI and I run only Valvoline 10w-30 VR1 racing with a Mobil 1 Exttended perf filter. I currently set the OCI at 4k or once a year. It's been a year today it only 1,803 miles. Planning a trip (08/14/17-08/30/17) to southern ca. From Seattle area. Should I just roll with it and change it when I return?
