Originally Posted By: Riz
Going to change diff fluid in my o9 ram. I know I need to use 75-140 syn. There are soo many choises out there don't know what to use.
I am a Dodge guy at heart and have had a lot of Ram's over the years( I would still have my 08 Ram w/ HEMI I just sold if not for becoming ill and the resulting financial issues ). The last 3 called for 75W-140 in the rear diff. I have always used Royal Purple MaxGear in my trucks. I used the 75W-140 as required in the last 3 and it worked very well in those applications.
If you have the 3.92's w/ LSD the RP gear oil has the FM already in it and you shouldn't need to add more. Sometimes an LSD gets picky and will require a little extra be added but best bet is to try it without any extra 1st. That actually applies to any brand with FM in it already. If you do not have the LSD do not worry as the FM won't hurt anything.
I recommend RP MaxGear 75W-140. It meets all of your warranty requirements and is a premium product.
Question??? Is this a 2WD Ram? If it is 4WD don't forget to do the front diff as well. Always do them together as maintenance unless there is a specific reason such as a failure that causes you to do a change. Front is 75W-90 and again I recommend RP.
