Interesting fix from The Car Wizard. Figured I could get 4 million opinions and discussions on here as I watched it.
That guy, or any of those Ford techs and their Lucas better stay away from my engine.
What engine? What weight oil were they using?
If you watch the video, he initially called BS on the suggestion to use Lucas.... he then hooked up an actual oil pressure gauge after putting it in there to verify it was working. I do agree however on just running a higher viscosity oil instead of adding Lucas to a thinner oil.If lucas was his fix hes not much of a mechanic in my opinion. I would bet money they were running 5W20 oil. Why not just go up a grade and skip the junk lucas?
It's a 5.4 3V (he states in the video), I would be willing to wager he has a worse version of what is wrong with my MGM-the timing chain tensioner seals are failing and allowing the oil to leak out, and will eventually result in cam/head damage. Thicker oil will mask the problem for a while, but it will toast the heads eventually. Guy's a hack for using Lucas anyway, he should use Rislone or STP!! (sarcasm mode off)The owner commented that it is a 5.0.
Assuming we believe him, for this particular truck, the solution worked. That doesn't mean it will always work or that there is not another way to accomplish the same thing.
Interestingly - My work truck exhibited the same symptom at a much lower mileage and something completely different fixed it, its a Ford but not a 5.0 or an F150.
I hope the Wizard fixed that grill while he was there...
The engine actually requires the new 0w100 formula.It's a 5.4 3V (he states in the video), I would be willing to wager he has a worse version of what is wrong with my MGM-the timing chain tensioner seals are failing and allowing the oil to leak out, and will eventually result in cam/head damage. Thicker oil will mask the problem for a while, but it will toast the heads eventually. Guy's a hack for using Lucas anyway, he should use Rislone or STP!! (sarcasm mode off)
I love how not even 2:00 in he says "Really sad how they designed those engines." when speaking of the 5.4 3v
Name me an engine besides the Coyote that Ford has made in the last 10 years where you can't say that!
Praying the 7.3L...........I love how not even 2:00 in he says "Really sad how they designed those engines." when speaking of the 5.4 3v
Had an F150 with the 3.5 EcoBoost on a farm I managed. It was a POS at low mileage that ended up with rod knock on two cylinders and we had to threaten with a lawsuit and force Ford to buy the truck back. It's fine to have a junk product if you stand behind it. Ford doesn't. What's better is that it got HORRENDOUS fuel economy. Worst I've ever seen in a light duty pickup.Dad used to have 8 pickups with the 3.5 EcoBoost engine in his fleet of company vehicles. All 8 had major issues, and he swore to never own another EcoBoost engine in anything, ever again.
I think a lot of people are. If I had to buy a Ford tomorrow that would be the engine I'd be buying. I hope a pushrod V8 is hard to screw up but those silly engineers, bean counters, and CAFE regs always find a way.Praying the 7.3L...........
