- Joined
- May 28, 2014
- Messages
- 2,261
Very few cars use M1 anymore.
I won't use it anymore in the supercharged mustang I've got. Haven't used it in years,not impressed with Mobil1,using Schaeffer oils for that car.
I haven't experienced stuck rings since API SH.I have used true synthetics in demanding applications with good results . It depends on how much you enjoy hot stuck rings and their concomitant power loss and damage vs. proper cylinder balance. The real bad actor had been the VM load in severe multigrades like 5W30. The VM chemistry have improved over the past could decade where they are not as problematic.
Still I have recollection of stunning and consistent running engine with a well formulated true synthetic.
Some Toyota NON-hybrids spec 0w-16 at least since 2018. My Camry is an example. I recall so many saying this engine would surely grenade in no time. Referred to it as "disposable". I've only about 50,000 miles, but, it can be over-filled by about 1/3 of an inch and still not lose a discernable amount in 5000 miles (the interval I've chosen to use). And, this engine can get over 50 mpg with three adults on a highway trip staying within the speed limit (from 55 up to 70, mostly 60-65, although hilly).Toyota hybrids call for 0W-16, and it is pretty common these days at the local Autozone and Walmart.
As opposed to a random person on BITOG?Good ole Youtube... the pinnacle of factual information. If a random person on Youtube says the spawn of a donkey and giraffe is a batfish, it must be true.
Report back when it has 150,000 miles. 50k is barely broken in for a modern car and even the worst engines would survive 60k if the OCI was completely ignored.Some Toyota NON-hybrids spec 0w-16 at least since 2018. My Camry is an example. I recall so many saying this engine would surely grenade in no time. Referred to it as "disposable". I've only about 50,000 miles, but, it can be over-filled by about 1/3 of an inch and still not lose a discernable amount in 5000 miles (the interval I've chosen to use). And, this engine can get over 50 mpg with three adults on a highway trip staying within the speed limit (from 55 up to 70, mostly 60-65, although hilly).
Agreed. The point was, 0w16 didn't grenade the engine prematurely as so many predicted.Report back when it has 150,000 miles. 50k is barely broken in for a modern car and even the worst engines would survive 60k if the OCI was completely ignored.
Sort of like this motor oil which is both A3/B4 and API SP. Bottom of the barrel trash? Go back and do your homework.I'd be less worried about what the base stock is then what the oil is approved for. If you want the best performing oils, the simplest way to get that performance is to go with euro flavors or ones that meet ACEA A3/B4, ACEA A5/B5, Porsche A40, and the various MB/VW approvals.
Comparing API SP to any of the above mentioned makes it look like bottom barrel trash. It should be said however that if your car only requires API or ILSAC specs it will likely be fine. Most of the major brands exceed those specifications, but if you want the extra protection a Euro oil is the cheapest and easiest way to get it.
Yes. Opposed to them. Lots better on here.As opposed to a random person on BITOG?
I meant from a lubrizol comparison graph standpoint. API SP is dwarfed by pretty much all the other certifications.Sort of like this motor oil which is both A3/B4 and API SP. Bottom of the barrel trash? Go back and do your homework.
I'd say if a vehicle goes 150k whatever is being done is working.Correct and when you get to 150k the feedback will be to run it to 300k for a true test.
Yeah, just ignore their disclaimer not to use the tool that way.I meant from a lubrizol comparison graph standpoint. API SP is dwarfed by pretty much all the other certifications.
If you get better wear numbers from group III than IV, why would you use IV?
Well, I have over dozens of cars, over dozens of years so I would chance a guess that you have too.I haven't experienced stuck rings since API SH.
