Nascar is not applicable to passenger car use.
Odd comment, considering that when you look at some Mobil racing oils what is exposed as general formulation
Here is the M1R 0W30 SDS dated July 2020 :
Applications
Mobil 1 Racing oils are recommended by ExxonMobil for a wide range of race engine applications. Note: Mobil 1 Racing oils are not recommended for street use.
• Mobil 1 Racing oils are recommended by ExxonMobil for a wide range of race engine applications including highly loaded flat tappet designs such as NASCAR Cup engines
Hazardous Substance(s) or Complex Substance(s) required for disclosure
Name CAS# , Concentration* , GHS Hazard Codes
1-DECENE, HOMOPOLYMER HYDROGENATED 68037-01-4 70 - < 80% H304
2-PENTANOL, 4-METHYL-, HYDROGEN PHOSPHORODITHIOATE, ZINC SALT
2215-35-2 1 - < 2.5% H303, H315, H318, H401, H411
ORGANO MOLY-SULFUR COMPLEX CONFIDENTIAL 1 - < 5% H315, H317, H402, H412
PHOSPHORODITHIOIC ACID, MIXED 0,0 BIS (1,3-DIMETHYLBUTYL AND ISO-PR)ESTERS, ZINC SALTS
84605-29-8 0.1 - < 1% H303, H315, H318, H401,H411
ZINC BIS(O,O-DIISOOCTYL) BIS(DITHIOPHOSPHATE) 28629-66-5 0.1 - < 1% H315, H318, H401, H411
* All concentrations are percent by weight unless material is a gas. Gas concentrations are in percent by volume.
