Okay, I'm ready to do my first brake pad change this weekend. I think have almost everything I think I need to do the job, with the three remaining items being brake fluid, caliper grease and 3/16" ID vinyl tubing.
I've made myself a DIY version of the Motive Power Bleeder (just without the pressure gauge installed yet, though in a temporary hook up of a gauge, I have a good feel for where 15 psi to 20 psi is). Had to improvise something for the brake reservoir cap (for a Toyota), made with a Moen silicone toilet flapper of all things, and an old aerosol cap, improvised to put even pressure, and to be held on with duct tape to form a seal while I work. (Hard to describe, but it makes sense if you see it). My original design for holding the cap failed as what I was using wasn't rigid enough. For Toyota (or others with similar reservoir caps), I'll post my final design once I've got it worked out. The improvised version is because I don't have much time to get it done before the weekend.
My goal in this job is to replace the front pads, and bleed the brake fluid. Rears are fine. Front rotors are fine. I'm not asking for help with the specifics of changing out the pads, but do want some advise on the correct procedure in this circumstance.
Here's how I understand what I need to do, so if I'm wrong, please correct me:
1. Jack rear passenger side of vehicle, remove wheel. Hook up power bleeder, then bleed from the rear passenger side. Stop the bleed once clean fluid shows up in the drain tube. Reinstall wheel.
2. Repeat this for rear driver side.
3. Now, jack both front corners, removing wheels and supporting with jack stands.
4. Change front passenger side pads. Bleed front passenger side.
5. Change front driver side pads. Bleed front driver side.
6. With wheels reinstalled, and vehicle on the ground, start the engine, and pump the brake pedal several times until it is firm and no longer sinks to the floor.
Anything I should add, change or be aware of? Vehicle is a 2006 Toyota Sienna.
