Re-purposing an old iPad
Canuck - moved to —> California —> Texas —> ???
Recently I found my wife's old iPad, I think it's iPad 2. Other than being old and a bit slow for normal usage, it's in perfect working condition, so I decided to make some use of it.
I decided to mount it on the wall so that I can use it as a feed of my security cameras, but it can be used for playing music, even as an inside camera. The mount I bought can accommodate newer iPads, so if this one stops working I can always get something a bit newer.
The most challenging part was getting the power outlet install inside the wall, as I wanted to keep the opening as small as possible.
Here are some pics of the install and final outcome.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Looks great, but I wonder if having a receptacle box enclosed in a wall meets code.
Thank you, great job!
I have the same iPad in excellent condition just sitting around unused.
Whether I get motivated to do it is one story but, wow, what a great idea.
That's a great idea for a spare iPad. I've got a couple tablets sitting at work that I don't know what to do with so this is a good thought. We had the normal mount-it! wall-flat mount used for "time-keeping" so we can tell who's was in the office in case of an emergency but I took it down since nobody ever used it. Great, simple, cheap hardware.
Very nice KrisZ!
I hope the battery holds up.
My experience with repurposing old phones reflects what Uphill_Both_Ways pointed out:
That these devices overcharge their batteries at 100% so left plugged in for months and years the batteries swell to self destruction.
If only the phones and pads had an option to stop charging at 80% (for example) like some laptops have.
the batteries are dirt cheap for these things, you can probably get a new battery with a self install kit for ten bucks or so.
I've done a bunch of them, if you can put this mount together, you can put a battery in it.
Not sure about putting an ipad directly into a wall cavity though, safety wise.
Originally Posted by John_Conrad
install an electrical timer on that outlet and have it only provide power every 3 hours or at the interval that you know your batter draws down to say 20%
That's not a bad idea. I will probably get one of those smart plugs so that I can adjust the schedule without removing the ipad from the mount.
I was looking for a software based charge limit, as something like this is available for some Android devices, but I could not find anything for iOS devices.
I just remembered this thread and wanted to give an update on the battery. There are no issues with the battery. I notice that sometimes the battery percentage goes to 98%-99%, but for the most part it stays at 100%. The screen doesn't get hot or anything like that. So it looks like the software is managing the battery charging perfectly fine.
