Range Rover STJLR.51.5122
Does anyone know about this oil spec? It is very difficult to locate. I have a 2015 RR Sport HSE with 3.0 supercharged. I have 70k on it. LR recommends Castrol and they make a Edge Professional (E) oil but once again, not readily available. I called the LR dealership and service advisor said any good full synthetic 0W20 oil would suffice. Is this true? I read online and found that the Castrol professional oil only has a dye that detects leaks. No other differences? Please help. Thanks
use an acea c5 oil if you want the closest to factory fill. castrol edge ep 0w20 is the most readily available
most 0w20s on the market are more than adequate for the task regardless
Thank you! So Castrol Edge 0W20 should be fine I suppose.
Hi.
The following carries the approval you are looking for. If memory serves it is available in US.
