random noise at idle -bmw
Lexington, KY
1995 BMW 525i 6 cylinder.
Just finshed my coolant replacement (Zerex GO5) and expansion tank O ring repair and let idle with front of car jacked up.
After idleing long enough for the engine and heater to warm up, I started hearing a sharp noise like a valve or lifer from the valve cover area. Rev engine and it goes away and then comes back later. It also would come and go at random. I am at odds as to what this is. Except I just think prolonged idling with nose up is not a good idea. Will watch. BTW, this car does not have adjustable valves.
Any thoughts?
How many miles? These engines use hydraulic lifters so it could be one that is going bad or is slow to fill. The angle probably exaggerates this at idle since pressure is lower in general.
