ran a car without a dip stick
ca
Just noticed that my dipstick was misinstalled when I checked the oil last time. So put it short, my dipstick was not installed properly for maybe 2 days of short drivings, and bottom part of the car was covered with oil. I checked the level of the oil and it looks fine though. Should I worry about this?
Bonnyville, AB
It was just oil mist coming out of the dipstick tube, if the tube is in fine now, and the oil level is fine, you just rust-proofed the bottom of your car for cheap.
hibuhibu
ca
Score!!!!!
ON, Canada eh?
You're fine bud... \:\!
Sunny Calif
I would think it's bad because the engine sucked unfiltered air into the crankcase which was then burned by the engine via the PCV valve
OVERKILL
$100 Site Donor 2021
Ontario, Canada
I doubt it was sucking. Remove your oil fill cap when your engine is running and see if there is vacuum or pressure. I think you will be surprised to see that it is the latter.....
hibuhibu
ca
Yeah, I tried to clean some of it up but the oil is endless haha. I checked the oil but there is still plenty. I guess I have not spilled as much as I thought. It is smoking on the tail pipe though. Hopefully it goes away after few miles.
