I can't find RainX washer fluid at any W-Ms in my area. Is it still available???
quote:http://www.rainx.com/BB/default.htm RainX seems to think so. They also have some additional products: wiper blades, waxes, washer fluid, de-icer. .
Willy_G: I can't find RainX washer fluid at any W-Ms in my area. Is it still available???
quote:Yes, because you are in the manly State of Texas, whereas the poster who mentioned the Pink formulation was - like me- trapped in this lily livered pantywaist nation to the North. Practically every time I am in an Autoparts store I pick up a bottle of a fancy washer fluid - either Rain-X or the CDN Tire Teflon or something- but I never end up buying it. Just get fearful that it will harm paint or gum up nozzles or something. Ami just being a nervous nellie in my fear of Pink Rain-X or the Mauve stuff with Teflon?
Originally posted by blupupher: Never seen the Pink Rain X.![]()
quote:Don't be too hard on yourself and your fellow Canucks -- we have plenty of the pink Rain-X on the shelves here in Florida, which is obviously just as much Bush country as Texas. On a related note, I've given up on the Rain-X washer fluid. After experimenting with numerous combinations (and straight, per the directions), I just can't seem to get the stuff to stop making my wiper blades stick to the glass. It's awful to see and hear my blades chattering across the glass sounding as if the wiper arms are about to be torn off. Enough. Back to old fashioned Rain-X for me.
Originally posted by peterr:quote:Yes, because you are in the manly State of Texas, whereas the poster who mentioned the Pink formulation was - like me- trapped in this lily livered pantywaist nation to the North. Practically every time I am in an Autoparts store I pick up a bottle of a fancy washer fluid - either Rain-X or the CDN Tire Teflon or something- but I never end up buying it. Just get fearful that it will harm paint or gum up nozzles or something. Ami just being a nervous nellie in my fear of Pink Rain-X or the Mauve stuff with Teflon?
quote:The pink stuff isn't sold around here anymore. You can buy it online at http://www.clorders.com/shellrainxsub.htm
Originally posted by Willy_G: I can't find RainX washer fluid at any W-Ms in my area. Is it still available???
quote:Have you tried using the actual treatment for the glass first, or are you just using the windshield wiper fluid? You might try an application by hand of the bottled stuff, and use the wiper fluid to renew the effects.
Originally posted by ekpolk:quote:Don't be too hard on yourself and your fellow Canucks -- we have plenty of the pink Rain-X on the shelves here in Florida, which is obviously just as much Bush country as Texas. On a related note, I've given up on the Rain-X washer fluid. After experimenting with numerous combinations (and straight, per the directions), I just can't seem to get the stuff to stop making my wiper blades stick to the glass. It's awful to see and hear my blades chattering across the glass sounding as if the wiper arms are about to be torn off. Enough. Back to old fashioned Rain-X for me.
quote:Factor-in wind chill when reading those labels on windshield solution protection. Also need to consider sitting time. Not driving it all weekend during the winter may surprise you when you try the windshield washer on Monday morning at 5:30AM
Originally posted by Matt_S: I can remember it reaching -22F in Detroit once since 1978, when my family moved here. Normally, the lowest it gets is single digits above zero. Sometimes you see negative single digits. Anything lower is really rare. Upper Michigan is a different story, though. In your case, I'd feel free to use the Rain-X fluid during the spring, summer and fall, then switch to the super-cold-weather stuff during winter, when you really need it. It mixes with regular fluid just fine.
