I'll be replacing the radiator on my 03 suburban.
RA's website has a Denso for a reasonable price, but it includes the EOC. My rig is not EOC equipped. EOC- Engine OIL Cooler
Mine specs the 1" thick core, 34" wide. Though the actual measurements on the 1" radiators core range from 7/8" to 1".
However the ones spec'd with the EOC are over 1' thick. The Denso comes in at 1.3".
I like the thicker radiator with a schmekel more capacity.
Is it ok to use a radiator with EOC fittings that aren't being used? I can cap the EOC ports.
It also has the trans cooler which I will be using.
Thanks
Thanks
