Doug: Until a year ago I had the exact same 928 you did -- I called it "Red Beast" since it was so tail-happy during club racing events, and yes...it was red. (My '84 944, on the other hand, handled brilliantly on the track, even better than Britney Spears does in bed, or so I've heard.)
The more viscosity modifiers (such as in multiweights) there are in an oil, the less oil there is by percentage, and oil is what lubricates, not viscosity modifiers. Hence, Flimflam's advice regarding monoweights for race cars is sound, although it sounds like you may be referring to combination street/track cars which actually spend most of their time on the highway...? If so, a 20w-50 or other appropriate multiweight for your climate might be a good choice. Rather than suggesting brands or oil types, I would think that oil spec sheets that show a comparatively high flash point, high viscosity index, good high temp/high shear viscosity, good Noack, and relatively high zinc with a bit of moly thrown in might be helpful. Would others agree with this..? Or, to make life simpler, look into oils which incorporate some of these attributes and are marketed as "racing" lubes.
And at the track, always remember, "The shiny side faces up!!!"
[ November 06, 2003, 01:33 PM: Message edited by: TC ]
