- Messages
- 11
- Location
- ND
I'm new here and did a search on this subject but didn't find anything specific. I build and dyno test race engines, most with flat tappet cams and high spring pressures. I normally use a 10W diesel oil (Cenex 518) for break in and Amsoil 20-50 Series 2000 or 5-30 series 3000 after. (Break in, for me, means the first 30 minutes of engine run time and maybe a half dozen or so partially loaded pulls on the engine.) It's my understanding the reduced zinc oils are mainly the 30 weight variants of gas engine oils, the S rated oils in 5-30, 0-30, 10-30 etc. This is why I have got in the rut of using the Cenex 518 10W for break in. The last few years I've been paranoid enough about ruining a cam to add a bottle of Sealed Power LL-5 to the break in oil AND the Amsoil. I have a dyno test coming up on a Engine Masters Contest entry and for break in the engine builder wants "any name brand 10-30 from Walmart". I'm having a fit. I think since he wants a 10-30 I'll use Cenex 518 10-30, or better, the 518 15-40. The engine has Schubeck lifters in it because we will be testing a few different cams and with the Schubecks the AW additives (or lack of relative to flat tappet cams) shouldn't be an issue but paranoia is a hard thing to suppress. The final cam will use conventional all magnetic solid lifters.
So are there any specific suggestions or thoughts on this subject?
Thanks,
Jesse Lackman
[ September 12, 2003, 12:13 PM: Message edited by: BOBISTHEOILGUY ]
