I don't interpret the data in the charts the same way you do, Widman. It looks like both ring and bearing wear increase with rpm or load. It's just that the absolute rate of wear in much higher for the ring material at any speed or load. The most instructive information in the graphs is how a CHANGE in rpm or load causes a transient increase in wear. That's why hard acceleration increase engine wear. Hard acceloration and/or high rpm would be expected to have an even greater effect in a cold engine where it would take longer for the oil film to recover under conditions of low flow.
