OK, so the Camry threw a code and lit up the Check Engine lamp last week: Bad heater, O2 sensor, Bank 1 Sensor 1.
There was nothing visibly wrong with the removed one, it wasn't cracked, damaged, plugged, coated or otherwise visibly defective. It looked like a part that had been in the exhaust stream for 178,000 miles.... kinda brown tinted! Meter verifed, replaced it, no issue there.
30 minutes of work and the dealer wanted $200 for labor alone....but i digress.
Observation: the car is now running like the proverbial batouttaH*** on 87 octane (it prefers 91+). So I'm guessing the 02 sensor (1 of 3 btw) had been marginal for some time, long enough for me to forget how this pup could run. But not bad enough to throw a code?
The heater is a simple resistive circuit: it's either good ("X" ohms range) or not (infinite ohms, open circuit).
My question (finally, they say): does an o2 sensor in fact go bad over time **without** being bad enough to send an ECU code? The only test in the shop manual is the ohms on the heater. What about the actual sensor? How to test it?
tia for any intelligent answers...
