Originally Posted by krismoriah72
Motorcycle Specific means wet clutch i assume? JASO specs trump API?
The holy trinity of science is 1)Reason 2)Observation 3)Experience...
employing those tools we observe that the primary cause clutch slip
are high mileage... mileage is the constant among all of the clutches
that begin to slip... oil choice whether JASO approved or not is not a
constant... High mileage is the constant where all clutches begin to
loose grip due to normal glazing and contaminates that build up over use...
On UTVs which are basically just modern 4 stroke engines with fuel injection, catalytic converters.. SN would be more favorable than SJ/SL correct?
API SN oil would favor your cat... if you can't find a motorcycle specific SN a suitable alternative would be Auto SN...
Like it states in my profile... I'm using auto oil SN in my homolgated
race bike with a tall first gear good for 90mph... I literally
incinerate my clutch in WFO launches on the street or track... I don't
ride in moderation and yet no clutch slip issues due to oil... so
because of low cost and high availability I pick Mobil 1 5w30 SN but
any SN auto 30 grade will do...
Because Mobil owns 80% of the market they offer many 30 grades... I only know about the SN marked YES...
