XHVI,
ZDDP and MoTDC react similarly.
When I mention temperatures (in this context), I am referring to surface (metal-to-metal) temperatures, not the bulk oil temperatures.
ZDDP and MoTDC go into the oil solution and form organosulfur (carbon -sulfur) compounds.
At about 450 F, the zinc polyphosphates form a fluid glass; it is this glass that lubricates the surfaces.
At 500-800 F, the moly polycarbamates form a glass-like layer that lubricates the surfaces.
The dithiocarbamates of moly are often referred to as Anti-Wear additives, but also present Extreme Pressure properties as well.
The higher the loads (and after the hydrodynamic layer breaks down), the greater the mixed or boundary lubrication conditions that exist, and the greater the coaing effect.
[ November 20, 2002, 08:14 PM: Message edited by: MolaKule ]
