Interesting stuff! I typically change my oil out at 5000 km intervals, regardless of what oil is in there (even though it's been either a synth blend or a full synth). I realize I *could* go longer but I feel better just doing it. Plus it gives me something to do every once in awhile
![[Wink]](images/icons/wink.gif)
I guess the whole reason I'm here on this board trying to learn more about oil (and this is obviously the place to do it!) is that I recently had an intermittent oil pressure light.
Before you all go running screaming about engine wear or whatever, hear me out. It first happened around March or April, but I figured because I was driving the car really really hard, around a corner I figured I had just caught some air in the pump and it just got momentarily starved. Well happened again about 2 weeks ago. Diagnosed the switches and they were faulty. So I had both the high and low pressure switches replaced.
Unfortunately, this didn't solve the problem. (Remember I'm driving a 95 Golf 2.0 with Mobil 1 full synth and an OEM VW filter). So I took the car into the dealer for a pressure test and sure enough, as the car gets warm, the pressure drops off. The tech estimates the pump is working at about 90% of what it should be. Nevertheless, I decided to park the car until the pump can be replaced, which is this Thursday.
QUESTION!! Could the fact that I've been running a 10W30 or a 5W30 have ANYTHING to do with the failure of the oil pump? I'm kind of surprised that the pump is faulty...I've had other cars with much higher mileage and no pump promblems at all. (Like an 82 Reliant with 487k kms on it).
The car started out life with 10W30 dino oil consistently changed at 5000 kms. Never used anything but a VW OEM filter. I ran Castrol GTX then Valvoline, if that matters. At about 50k kms, I switched to Valvoline synth blend, then switched over to Mobil 1 full synth at about 90k kms and haven't used anything else since.
