We're looking at buying a house. Because of the age of the house 2 prong receptacles are throughout the house. But there are a bunch of 3 prong receptacles installed at various locations that are not grounded. To change the 3 prong to grounded receptacles an electrician would have to ground the entire house which means re-wiring the entire home.
The seller says they will not re-wire the entire home. The 3 prongs can be used, but they just won’t be grounded. If you have them put the 3 prong back the 2 prong then you won’t be able to use a 3 prong appliance unless you use adapters.
I guess my question is would it be safe to use the 3 prongs without grounding or to put the 3 prongs back to 2 prong?
I'm wondering if we should go ahead with buying this house.
Any advice would be appreciated.
