Welcome to the site Sidewalk.
The question you pose is like a political nightmare. There is no one good oil and most that really stand above the crowd usually are not OTC oil (over the counter).
So because you're looking for something for OTC oil, you'll find a majority of them are pretty good, especially since the new GF-3 base stocks have become a requirement to be API certified.
You need to determine, long drain intervals? or standard 3k, dirt road or on pavement mostly, pretty warm most the time? Do you drive hard? The oil you are currently using, are you haveing problems with it? If so, is it oil consumption or leaking seals?
Are you running the M1 tri synth or the supersyn?, If you're worried it might not be a good choice, do your 3k drains, then send in a sample to an oil analysis lab and see how it will check it. This will show you if you have to worry about changing it and not by what a bunch of guys say based on their personal feelings.
I myself have a bad feeling on m1's supersyn, but I cannot say for a fact it isn't a good oil. I suspect that the tri synth version of their oil will be better than the newer supersyn. Just preliminary things that I personally don't like but under your condition you may find out that you don't stress the oil and such. Another words, investigate first with oil analysis and determine if it is adaquated for your situation.
