Well, I think you have a valid point. This is one of the reasons I like Schaeffers so well. They do their own in house spot checks on the different products they produce with their own in house lab. For example, here they use a grease penetration tester for consistancy of their greases...
Now, for those that are not aware on how oil is checked let me take a moment to show you a little about a lab, in this case schaeffers in house lab..
Here is what they do to check for viscosity... first there's a viscosometer tube, notice the two lines, I numbered them 1 and 2.
Now, here is the actual setup where this tube is used...
Notice the little bulb in his hand, what he does is takes a sample of the oil, places it into this tube, allows the oil to heat up in that bath to the 100deg C. After it is up to temp, he then puts that bulb on the small end of the tube and pulls a suction to bring it up past the #1 mark on the tube. Then he removes the bulb allowing the oil to drain back down. Now, once it hits the first(#1) mark, he starts a stopwatch, then as it hits the second mark(#2),he stops the watch. He does this 3 times for consistancy of measurement. Then once he is satisfied with the time, he has a conversion chart to convert it to centistrokes which then relates to visocity.
This is the FTIR, Which basicly gives you the base oils condition.
And then the ICP which looks at the wear metals..
Now you can see why this oil shows such high quality because of the QC procedures they use.
[ April 09, 2003, 06:40 PM: Message edited by: BOBISTHEOILGUY ]
