The API didn’t change any viscosity requirements with the SP license.*Fast forward to today : Would SP rated QSUD 0W20 & 5W20 synthetic oils have any appreciable differences that matter beyond what was stated in this thread ?
So it's for sure then that QS is in fact using GTL base?It really depends on the brand and formulation. For example, Mobil 1 EP 0w20 uses a PAO base oil which will have a higher natural VI, compared to the EP 5w20 which uses a smaller amount of PAO and in addition to Visom III+. In this case, the Mobil 1 EP 5w20 will have more VII's compared to the EP 0w20. With the QSUD, both using GTL, the 5w20 will use less VII's so that would be my choice.
It requires 0w20, but recommends Quaker State.Originally Posted by Tundra73
Originally Posted by ChrisD46
*OP here : Hyundai doesn't list 0W20 as an acceptable grade in the OM (as most know) ...
Since when? I have a 2017 Hyundai Ioniq and it calls for 0w20 in the manual, in fact is specifically says that Hyundai recommends Quaker State 0w20.
They say "recommends", according to what you wrote, which doesn't mean it has to be used.
Yep, my 2017 OM lists it.Originally Posted by Tundra73
*2017 Sonata 2.4L OM and Elantra before that only show 5W20, 5W30, 10W30 in the OM . I was not aware that Hyundai ever listed a 0W20 ?
Yes. The word "recommends," which means here, a product they're suggesting, or recommending. Probably for some kind of monetary agreement they have/had with SOPUS. You can use any 0W20 that meets Toyota's specifications, not necessarily QS.It requires 0w20, but recommends Quaker State.
Oh, I know. I was just commenting on it at the time because I had never seen an OM specifically recommend a certain brand before. Thought it was interesting.Yes. The word "recommends," which means here, a product they're suggesting, or recommending. Probably for some kind of monetary agreement they have/had with SOPUS. You can use any 0W20 that meets Toyota's specifications, not necessarily QS.
