PUP 0w-20 5K 2014 Venza V6
PA
I didn't shake up the 1 qt PUP bottles and the results are fine.
There was some residue at the bottom of the bottles. The TBN was 7.1
[Linked Image]
Wear metal ( Fe, Al, Cu)
[Linked Image]
Originally Posted by paulri
Just out of curiosity, did you figure out any possible cause for the spike at 46K?
Wrong sample or contamination(???)
As matter of fact, Fabick Cat did the sample at 45978 and 14428 and both sample detected a level of 1 ppm Pb.
Highly suspect.
I should have asked the lab to do a redo. My mistake, You only have about two days before they dispose of your sample.
I had Blackstone do a redo when one sample showed up with Pb.
I was OCDing on the excel spreadsheet and I needed to clean it up for readability.
[Linked Image]
