Speaking about the current 2019 versions of these two oils only -
Pennzoil Platinum 0w20
Pennzoil Ultra Platinum 5w20
Excluding the following variables from any consideration whatsoever:
1. 0w vs 5w doesn't matter as the temps never drop below 25 degrees farenheit
2. Price is exactly the same between the two
3. Availability of both oils is equal
Including the following factors:
1. The two subject oils only (the Pennzoil Ultra 0w20 is not in consideration here)
2. Start stop traffic, with about 4 runs each day for 15 minutes each run in 30F to 45F temperatures in winter and 80F avg in summer). Basically oil never reaches and sustains optimal operating temps
3. Honda VCM, OR Hybrid Atkinson Cyle engines
4. Long OCIs (~5-7K on Honda VCM to 10K on hybrids)
Which will perform better and why? (subject to the exclusions above)
Thanks
Desh
