2016 Hyundai Tucson 1.6 T-GDI and 7-speed DCT trans., 76,000 miles.
I recently tore down this engine to fix a burned valve, which I learned these engines are known to do at varying not-high mileage after diagnosing a misfire which revealed 0 compression on #4 cylinder. I have no idea how frequently the oil has been changed, but it did have a Valvoline sticker in the windshield with 3,500 mi. left on it, yet was close to 3 qts. low on oil with no visible external leaks. In addition to the burned valve, every cylinder had this spot worn smooth at 6:00 and 12:00. Upon fixing and test-driving about 25 miles, I observed it's tuned to stay below 2,500 RPM unless you really hammer on it. Even climbing a 5-6% grade at 65 MPH, it knuckles down in 7th gear @ 2,000 RPM - which feels great to the average driver, but that's a lot of low-end torque from such a small mill with (looked up pics) very short pistons without a full skirt. It really looks like side force on the pistons ovals out the cylinders which leads to the oil consumption they have an extended warranty for. I could be off base here but I feel like it's very unlikely this engine's just been maintained so poorly for its short life that neglect is the primary root cause.
For your consideration...
