Truck is a 2001 Silverado 2WD with rack and pinion steering. I flushed last summer with a quart of the GM stuff, 4oz Lubegard p/s protectant, .5 oz Lube Control, and some Pyroil fluid to top off.
The system has seemed noisier since the flush, so I'm looking for a synthetic fluid. The manual specifies GM p/s fluid #1050017/1052884. My local choices are:
Royal Purple MaxEZ
Red Line Power Steering
GM cold-weather/synthetic
The dealership stuff is $17.88 per quart, so I'd like to use one of the others if possible. I'm avoiding Valvoline Synpower because of the stop-leak additives. Red Line lists the GM part# on the bottle and web, but it is very thin and some recent posts mention noise and leaks with this fluid. RP does not list factory specs anywhere.
Can anyone recommend one fluid or the other? I'd especially like to hear from drivers of the 2WD GM's with rack and pinion.
Thanks and Happy New Year.
Royal Purple MaxEZ
