PS cooler
Where you are (CA) I would add one, it will only serve to save your pump and your steering unit and has "0" downsides IMO.
Doesn't need to be anything extravagant, even a pipe that goes away from the engine heat then back again is more than enough. My Santa Fe has one that goes up against the lower cross bar in the front engine area, no fins, just a pipe that touches the bar to dissipate the heat.
My 85 F-250 uses the line looped around the front cross memeber and my 2000 F-350 has a tube and fin cooler that's LITERALLY bigger than the factory cooler for the transmission on my 1994
Originally Posted By: Chris142
Originally Posted By: J_Myler
If its that big maybe you could use it as an oil cooler.
Engine oil? Naw it's only got 3/8 lines on it.
Ahh I see a little too small
