What are the pros and cons of using diesel oil in a gasoline engine? I know diesel oils has more additives and detergents and such, but is that the only reason?
Pros: more ZDDP.
Higher initial TBN
Lower cost due to less marketing.
Cons: higher ZDDP (not good if you are a frequent oil changer and have emmissions gear, but probably not an issue if you do extended drains).
Typically only available in heavier viscosities.
May not be readily available.
There is a 10-30 available, but that is the thinnest I've heard of.
Normally 15-40 or 5-40.
This is a bit thick for modern cars. Not a big deal in Summer, but cold starts in winter will suffer -flow and drag.
I think if they had a5-20 and 5-30 HD oil, everyone here would consider using it, otherwise.
Hi,
saaber1 - "Magnesium" is typically used as a detergent. It is being replaced in some HDEOs by the more expensive "Calcium" products
HDEOs that are not endorsed "mixed fleet" and carry dual petrol/diesel API/ACEA Quality ratings should NOT be used in petrol engines. This especially applies to those with a very high TBN due to their likely SA levels
Just want to clarify your statement... Are you saying that, if they do not say "mixed fleet", even though they may be SM rated, they should still not be used in a gasoline engine?
Hi,
Hi,
So I should return my Shell Rotella-T 5w40 Syn I bought for my Cabriolet?
Hi,
Hi, Doug
Could that be stated: Shell Rotella YES Shell Rumila NO
Hi,
Gary - Hi there. Yes many Commercial lubrication products are market and marketplace (country) specific
The last Specification Sheet I've seen on Rotella T Synthetic 5W-40 (not sold in Australia) shows that is dual rated
