On battery warranties, if you get another battery under warranty, even if you have pay money in on a pro-rated warranty, the warranty does not start over again. Is that correct? Does that work that way with Motorcraft batteries? All others?
You say the warranty starts over based on that date. Is the warranty different based on the date?If it is in the pro-rated portion of the warranty, and you pay a portion, the warranty starts over based on that date. Note you must keep the receipt in order for a dealer to process the warranty.
That all being said, Ford is transitioning the Motorcraft Max batteries to just a 3 year free replacement warranty with no pro-rated warranty. The new batteries that are being delivered reflect this, but I am not sure of the actual date this goes into effect.
Thank You. Last time I tried to run a pro-rated warranty, the staff at the parts counter told me that the warranty doesn't start over again. But haven't seen anyone say that here with anytime a pro-rated warranty is supposed to be with any brand. Not surprised that Motorcraft would be eliminating the Pro-rated warranty, since the idea of a warranty would be you don't want your consumers to have to be using it.Yes, it is all based on the date of sale. The date on the physical battery itself is irrelevant. So lets say you bought a battery 5 years ago, and had it warrantied out at a dealer and paid on this date. The 3 year free replacement / 100 month pro-rated warranty starts over because you participated financially.
I am making the assumption here that everyone understands it is a total of 100 month warranty and the first 3 years are free replacement. Some people don't seem to grasp this, but I assume anyone on here gets it.
An EverStart Plus battery has only 2 year free replacement, then it's completely out of warranty. There is no pro-rating.Ford used to prorate from the last purchase date weather or not the last purchase was a fresh new purchase or replaced under warranty and prorated.
Today I found out they changed the policy around 2018 where if the battery was prorated already, they go back to the original fresh new purchse date.
After 25 years, I today went to Walmart and got their 96r 590 for $99 and will no longer buy batteries from Ford or recommend anyone else does. I have 4 Fords btw.
Walmart 96r590
I'm fine with that, Its cheaper to replace and readily available close by and just about anywhere, save a trip to the slimy and sleazy dealership.An EverStart Plus battery has only 2 year free replacement, then it's completely out of warranty. There is no pro-rating.
Speaking as a former AAP employee your warranty is a specific number of months say 60, any replacement does NOT start another 60 that's what you bought that's what you get !!On battery warranties, if you get another battery under warranty, even if you have pay money in on a pro-rated warranty, the warranty does not start over again. Is that correct? Does that work that way with Motorcraft batteries? All others?
