- Messages
- 157
- Location
- Roseville, MI
I want to be sure that I use oil analysis correctly so I wanted to ask some people with more experience. I have been reading and it seems not all analysis's are created equal. Here is what I would like to do to determine the best oil for my vehicle.
Using the same oil filters for all. Is this the proper technique?
Using Castrol 5w30 conventional motor oil I have changed the oil once at 800 miles and will change again at 3K. I will sample from the second drain at 6K miles.
At 6K I will change to Mobil 1 full synthetic and go to for 4K miles. Drain, sample, and refill with Mobil 1. If the analysis looks good I will take it to 6500-7000K and sample again. Whichever results work the best I will go with that oil at that change interval.
I have some of the Blackstone kits, but do I need to ask them to check for any items that may not be standard on their tests to determine the best oil with proper change interval?
Thanks for the help!
Jason
![[Burnout]](/forums/graemlins/burnout.gif)
