Even since I was young, I had always been taught that a differential is full when the fluid comes running out the fill hole. The same was believed for manual transmissions and transfer cases.
Is this always the case?
My Silverado owners manual states this:
Quote:
For all 4.3 L, 4.8 L and 5.3 L
1500 Series applications, the
proper level is 1.0mm to
19.0mm (0.04 in to 0.7 in)
below the bottom of the fill hole,
located on the rear axle. Add
only enough fluid to reach the
proper level.
1mm to 19mm. Strance, it sounds like anywhere in-between that range is OK.
proper level.
