Not easily done on the 2AR-FE engine due to the location of the valve.As part of every service a shot of carb cleaner goes in, shake it, then shake the liquid out.
So that comes back to appropriate OCIs. yes? Or using an oil that has a high TBN to begin with.My belief is that it’s not about NOACK, it’s about TBN.
If you let the oil get acidic, varnish starts to form, and that will make the valve sticky. In some systems, they’re prone to sludge, again, a function of oil acid/base balance.
The valve on my Camry is approaching 12 years and 100,000 miles and still seems to be functioning quite well. I've always thought that such mileage and time would suggest that the valve is coming to the end of its useful life. I'd like to avoid replacing it for a while, if possible. It's nice to know that at least the potential is there for a long and useful life. Thanks for posting your experience.The original PCV on my Mazda was still ok at 600k. Mazda did not recommend a replacement or service interval, so I didn't.
It doesn't seem appropriate for the Camry due to the location of the hoses and PCV valve and because the engine is not DI. I could be wrong, and would gladly listen to any explanation as to why I might be wrong, but right now, with what I know, I'll pass on the catch can idea. Thanks for jumping in.How about "Here’s How an Oil Catch Can Works, And Why You Might Want One" - https://bit.ly/32ebuG1
Ed
Generally, the oil is changed at 6 mos or 5,000 miles, usually at 6 mos which is somewhat less the 5K. A PCV valve is a lot less expensive than a Honda, but thanks for that thought-provoking idea.I replaced the PCV valve on my Honda V6 well after 100,000 miles. The old one still rattled quite easily.
So you could buy a Honda. Or change the oil regularly (following the OLM, mine averages almost exactly 8,000 km/5,000 miles).
Because it's difficult and expensive to change and I'm unable to do it myself.Literally one of the cheapest parts you can buy, why concerned about getting longer life out of it?
Camry lolWhat type of vehicle? I need to add this to my list of--> never buy a car that...
There's another way to R&R the valve, and it's very similar to the method used on the BMW N52. It's easier but takes a little longer, and like the BMW, it's all done from the top. LOLCamry lol
IMO, it's not just about rattleing. The spring gets weaker with time.I replaced the PCV valve on my Honda V6 well after 100,000 miles. The old one still rattled quite easily.
