I think I am having a problem with the coolant hose that goes from my radiator to the recovery tank, it is original, its on a 1983 Chevrolet El Camino. The hose feels very soft and I can squeeze it very easily. The problem started a week ago when I noticed the lower radiator hose was leaking, its fairly new, made sure it was tight. I cleaned out the recovery tank and it was fine for a day and then started leaking again, this is when the car has been driven a while and a few drips come out, my thinking is that the hose is collapsing and not letting coolant flow into the recovery tank, the past 2 days it has not leaked, but today the recovery tank was low and I filled it up a little, but whether the car is hot or cold the level is the same. I am going to put a new hose on tommorow, I do not suspect a head gasket leak because the car is running great and there is nothing wrong with the oil on the dipstick, so let me know if this is something simple like a worn hose just collapsing under pressure. I will be at CarQuest tommorow.
