Yeah, there is an adjustment. I am wondering how much slack is needed, and if it would be causing my cold shifting problem. When I first take off in D, it hangs until about 3K
is it frayed and stretching? If you cant reach full throttle, that may be the reason. I was puzzled about a drop in performance for a while, then the cable broke.
Mash the pedal to the floor, and see if it opens the throttle fully [may need a helper]. Slack is usually meaningless if the throttle is opening fully when you want it to.
