hey djlinux, how do you know a wrist pin has failed? One wrist pin is a very odd part to fail on a gently driven car, even if you run out of oil other parts would fail much quicker. What did you run nitrous or something? These engines are well designed and run best when run hard. Babying it is a good way to stick the rings into place (bad) and lose compression, esp if it's been babied it's whole life. I would use a HM oil or straight SAE grade as previously mentioned and would stay away from the superthick, wideviscspread 5w50.
