Originally Posted By: FXjohn
My mother's avalon has this problem. I tried painting it with some special stuff out of a spray can from advanced auto, no help.
when I look at it in the fall, always green corrosion.
Somebody broke the case/post seal through over-tightening the terminal. There is no fix other than a new battery.
When you do replace the battery DO NOT reef-down on the terminal nuts!!! EVERYBODY does this, then they wonder why they get the green stuff.
The nuts ONLY need to be JUST tight enough to make it impossible to wiggle/rotate the terminal on the post with gentle finger-pressure. It takes VERY little, believe me.
When tightening the terminal nut, use two fingers and your thumb on the 10mm (or whatever) wrench, and push down about as hard as you would when closing a water faucet. ***NO HARDER***. Believe it or not.
