used on PSA diesel engines. piston to valve contact supposedly breaks the interference fit of and the engine stalls, mitigating damage.
cool stuff. skip to 13 minutes
The SHO Yamaha was a V6.Didn't the Yamaha V8 used in the Taurus SHO have problems with the cam lobes walking out of position?
the jellybean had a V8. made out of an extended duratec block and their own heads. cam sprocket liked to break offThe SHO Yamaha was a V6.
I should have known that! Only 3.4 l, if I recall correctly - pretty small for a V8. (Edit: Wiki says the Yamaha engines were 3.0 and 3.2 l. There was a 3.4 l V8 later, not a Yamaha.)The SHO Yamaha was a V6.
The late 90s Taurus SHO was a V8. Machining was finished by Yamaha. The problems it has was that the cam sprocket was press-fit to the cam. It eventually would work loose and destroy all kinds of parts. The fix was to weld the sprocket to the camshaft.I should have known that! Only 3.4 l, if I recall correctly - pretty small for a V8. (Edit: Wiki says the Yamaha engines were 3.0 and 3.2 l. There was a 3.4 l V8 later, not a Yamaha.)
UVVT - Unintentional Variable Valve Timing. Oops!The late 90s Taurus SHO was a V8. Machining was finished by Yamaha. The problems it has was that the cam sprocket was press-fit to the cam. It eventually would work loose and destroy all kinds of parts. The fix was to weld the sprocket to the camshaft.
