Originally Posted By: Gary Allan
I don't see the chain being lightly loaded unless the springs are lightly loaded or the lobes not too challenging in lift. I can't separate one from the other(s) ..in my head anyway. You've got a 2:1 gear reduction, but enough is along for the ride. I don't know if one could measure metal fatigue on the same plane as abrasive wear, but chains stretch. What I'm saying (or asking really) wouldn't that kinda discount the lightly loaded part of it?
I guess it depends on what you mean by "lightly" loaded
My meaning was that you don't see the same kind of metal-to-metal pressure (in terms of PSI) on the chain rollers that you do the lobes. The chain spreads the load out over a bunch of links, the lifters have a
tiny little contact patch so its thousands of PSI pressure.
And Zaedock wrote:
Quote:
The chain tentioner in a 2.5L/4.0L engine is a drag style. IMO, that's where some of the iron comes from in UOA's.
Actually its not a "tensioner" Its just a snubber. The chain doesn't rub hard against it under tension, the chain just "rattles" against it to damp vibration. I don't think the snubber accounts for much wear, myself, but then I'm just guessing. It is a part that most chain-timed engines don't have.
Another reason I don't think the timing chain does much to oil compared to the lifters is that there are lots of other engines out there with more complex timing chains and snubbers (Ford Modular, Chrysler 4.7, Cadillac Northstar) but they all have roller lifters. I don't see anyone posting "meat grinder" oil results on them either.
You guys may be exactly right, just explaining my train of thought.
