Can't blame it on Blackstone this time.The valvoline pdf states 800ph and 940zn and the analysis is under
Ravenol EFE 0W16.Both have good Noack's for 0w20's. I consider anything under 10% good.
I will wait to hear OVERKILLS thoughts on this oneLooking at the MSDS of the AFE, it appears they are mostly GTL base and no longer uses a decent PAO (30%) content; as before on API SN.
What’s the opinion these days on GTL vs PAO?
Note- M1 EP HM oil also has GTL base per their Feb 2022 MSDS.
I’m wonder if regular EP is to follow? The most recent one was Jan 2022 and still showed PAO base.
Funny there would difference between HM and regular EP. Unless the HM is indicating their regular EP is headed that way.
Paging @OVERKILL your public awaitsI will wait to hear OVERKILLS thoughts on this one
The HM oils have always been formulated differently, I wouldn't read too much into that.Looking at the MSDS of the AFE, it appears they are mostly GTL base and no longer uses a decent PAO (30%) content; as before on API SN.
Interesting. PAO content seems to be more a boutique oil find these days.The HM oils have always been formulated differently, I wouldn't read too much into that.
PAO is really only a luxury we see in this segment with Mobil's products. Shell's whole portfolio is based on GTL, it's an excellent base oil, though isn't quite as strong in oxidation resistance or cold temp performance as PAO, but for most applications, it won't make a difference, we are splitting hairs.
AFE is 50-60% GTL, we have no idea what the rest of the formula is, but PAO isn't called out (which it usually is) so it's a curious one as to what makes up the remainder.
EP was originally between M1 and AP, there was never an HM version of AP, just regular M1 and EP. When AP was discontinued, at least with the 0w-20, it looks like they just turned it into EP.Interesting. PAO content seems to be more a boutique oil find these days.
So, M1 keeps the EP label, but goes with a completely different base stock for the HM flavor.
I guess that part is a little surprising to me. I assumed it was PAO as well. What’s the point of calling it “EP” still? Maybe the GTL just blends better with the extra additives the HM oil calls for.
Might swap back to regular EP!
Makes sense.EP was originally between M1 and AP, there was never an HM version of AP, just regular M1 and EP. When AP was discontinued, at least with the 0w-20, it looks like they just turned it into EP.
The base oil selection isn't really relevant to the oil being SN or SP, or at least has VERY little influence, if any. Additive selection and treat rates would be what changed, if they changed. GTL is cheaper than PAO and easier to formulate with, so, if you can reach your performance targets using that, why wouldn't you?Makes sense.
In your opinion, is this newer GTL base AFE a better, worse or roughly the same product as the former version which had a decent percent of PAO base?
Perhaps the newer API SP requirements are relevant as well to the opinion of “better product”.
Is XOM catching up to Shell on the GTL base production? Last I recall was the marketing Pennzoil had several years ago on the GTL oils and then PurePlus. I can’t say that I recall other brands promoting that.
The AFE 0W-20 seems to have more Zinc and Phosphorus than EP 0W-20, and considering that it's majority GTL, it leads me to believe that Mobil does not use ANs in AFE 0W-20.Does this imply that Mobil has higher expectations for EP 0w-20? Perhaps.
I like Ravenol products, and the only distributer, Blauparts, is a great vendor. I can't justify the cost using it in my Optima, but I a few months I plan on selling it and getting a 3.3 l stinger which I plan on doing extensive mods on which I then will use a boutique oil.Ravenol EFE 0W16.
Noack 6.8
HTHS 2.4
Jaw dropping.
