PQIA Tests Amsoil OE 0W-20 Thoughts?
Originally Posted By: zuluplus30
Its implied. Amsoil and their reps have done everything under the sun to assure people it meets X performance level for warranty purposes EXCEPT formally license it.
And all of that flapping around (and cost) could be put towards getting the certification instead.
Originally Posted By: Tom NJ
Certification against API and ILSAC specifications is dirt cheap and, in my opinion, the lack of a such certification marks on products qualified to use them is a red flag.
According to Amsoil's FAQ, they cite other reasons (not cost) for lack of API certification.
FYI, I am not agreeing or disagreeing. Just providing info.
Quote:
Is there any flexibility in manufacturing an API-licensed formula?
Answer: API licensing was originally developed for mineral-based oils, and it affords these oils more flexibility than synthetic oils. Conventional oils comprised of petroleum base stocks may use a simple program called base stock interchange for added flexibility in manufacturing and purchasing. Interchange means that by completing the proper paperwork and running a few minor tests an oil company can choose to buy these petroleum base stocks from many different suppliers. This ensures adequate supply and competitive pricing. However, synthetic base stocks are supplier specific and base stock interchange is not allowed. For example, if a formula was tested with an ester base stock from a specific supplier then only that supplier's ester can be used. Complete engine testing would be required to use that exact same ester from another supplier and is therefore not performed because of the associated costs. This inflexibility makes price negotiations with synthetic base stock suppliers very difficult and increases business risk. Supply disruptions from only one source could shut down production.
There is also something called viscosity grade read-across. Fortunately, this applies to both petroleum and synthetic base stocks, although the better cold-temperature performance of synthetics makes it more difficult to achieve in some situations. The read-across guidelines ensure that if a manufacturer properly formulates the lubricant for which all of the API tests have been performed, then the manufacturer may use that same basic formula to make more grades (i.e. 5W-20, 5w30, 10w30, etc.) of the same motor oil.
Finally, there is a rule for substitutions in the Chemical Manufacturers Association (CMA) code of practice that allows a small degree of flexibility for all formulas. It allows a company to make changes to certain components in the formula with limited testing and paperwork requirements, provided that the additives are at the same or higher concentration.
Quote:
Why doesn’t AMSOIL license all of its synthetic motor oils?
Answer: If all AMSOIL motor oils were API licensed, the company could not source new raw materials from multiple suppliers, which would greatly increase the threat of supply disruption and the likelihood of extraordinarily high prices. To solve this problem, the API must establish base stock interchange guidelines for synthetic base stocks just as they have for other base stocks, as well as develop interchange guidelines for other components too. Furthermore, licensing formulas limits the ability to quickly adopt new technologies as they are discovered; each variation from the originally licensed formula requires re-submission for complete engine testing (see the Ask AMSOIL entry above for more information).
Originally Posted By: kschachn
Originally Posted By: Kuato
I'm with Tired Trucker here -- even if an oil isn't certified it can exceed the standard and be just as good if not better than an off-the-shelf oil that HAS paid for the certification. (Kind of like your company being ISO 9000 compliant but not paying for the certification - it's a racket).
So Amsoil likely meets the standard - or at least will protect more than sufficiently - the same as any other oil.
That is a non sequitur. What would lead you to that functional conclusion?
I thought Latin was a dead language.
However there are all those sterling used oil analysis to back up my statement; if Amsoil was brand new then I would agree there's no basis for the conclusion...but 40+ years of good results can't be ignored.
And the statement in bolded italics is my itch as well. As an independent formulator, I find that the API rules are roadblocks to using advanced technology components that may increase performance of a formulation.
Being a mainstay is no guarantee here. Oil companies change formulations all the time. Take Mobil 1 0W40 for instance. It had BMW approval for some time. Once reformulated late last year or so, they removed that approval until further notice. An non-certified oil would have nothing to remove from the bottle because it never had it to begin with.
There are a lot of sterling used oil analysis for a lot of oils. In fact, when was the last time you saw a bad one that could be attributed to the oil and not some defect or deficiency with the engine?
Also a used oil analysis isn't likely to show that something connected with a specific certification is lacking in the oil's performance.
There's a reason the agencies have those change restrictions on the certifications. I mean, just look at the post-Katrina Mobil 1 issues.
That whole explanation sounds like a bunch of obfuscation to me.
Basically, it sounds like they want to be able to switch ingredient suppliers at any time, possibly in order to get better pricing, and they don't want to have to go through recertification process every time. I understand that from a business perspective, but you as the end consumer really don't know what impact these changes have on the final product. All other major motor oil suppliers don't seem to have a problem with the API process.
Hard to pass up Quaker State Ultimate Durability for this.
I think Amsoil likes to fly in the face of convention with the API thing.
A lot of people that use their products have a similar unconventional approach in that they don't observe conventional OCI's.
It's that I know better because... philosophy.
All this song and dance about multiple suppliers to keep price fluctuation down is lost on me when they send me , a PC, an email announcing a general 6% increase this year. I can't help but notice EM, Shell, Ashland, etc don't have theses same issues. And yes I specifically mention Ashland as they are a blender just like Amsoil yet who is supposedly hamstrung to specific formulations at the mercy of the API. And the ability to adopt to new technologies is lost on me too since the SS line still uses a decidedly older add pack of calcium overdose. Given that the major players are trending away from such additives given LSPI issues, here I am scratching my head again at Amsoil supposedly at the forefront of technological advances.
I have a dark fascination with Amsoil. Not going to lie. But every time I try to justify it, I get mixed up in discussions like this.
Why anyone would feel compelled to purchase their lubricants from a MaryKay/AMWAY/Tupperware marketing pyramid is just beyond me. I'm glad the PQIA exposes borderline scams like this.
First API synthetic in '72 - but now has so many products it would be expensive to have too many badges on all.
If one is not willing to pay for Amsoil Signature - why not just go for high use proven products at a moderate cost per OCI
In 1972 the API was SE, with lots of AW, in premuium products. More than today's SN. That's why the 72 SS would fail API. Good for the engine, but bad for cat.
Interesting comments from Mobil post Katrina..... Katrina oil
Seems to be posted quite a bit on the specialty car sites. Some sites even spelled "received" correctly. I couldn't verify as actual.
"Suitable for" seems to be the refuge words for even the big boys if the situation warrants it....
That's EXACTLY why they do it...buy whatever off whomever, and still say it's exactly the same.
I've put that out here before, and been told no, it's because certification somehow makes a product worse.
I wouldn't exactly go that far. Amsoil's marketing technique is what it is. It's convenient and useful for some, and not for others. Looking at regular pricing of motor oil in Canada and the massive markups that retailers here use, Amsoil's techniques are the least of our worries. It's interesting to note that at the occasional retailer that sells Amsoil in Canada, it tends to be priced competitively versus the Mobil, Castrol, and Shell synthetics.
Well that's exactly why they say they do it, but come on how often does that reallyl happen? How many suppliers of such things are there in the world? They constrain themselves for some products that do carry certifications so that must be some sort of a purchasing logistics nightmare to keep it all straight.
That's exactly how I see it. In doing so it makes it a lot easier for them, they save money, and if they can grab a better price along the way they don't have to go through the re-certification process. Win, win and smart business when you think about it.
