Whenever I see these types of charts posted I’m always confused. Am I supposed to be able to tell which oil is better or worse based upon those numbers? And if so, which numbers do I look at? Do you know which ones make an oil better or worse? If you went to the work of putting together that table I’m guessing you do.
And since the numbers represent only the atomic makeup of decomposed compounds and also only show metallic elements how does that affect your decision?
Okay sure. What do the differences mean then? Using that chart, which oils are better than the others? I don't necessarily mean which one is "best", but using the numbers and the elements which oils are better than others?This is the purpose of an Oil Forum and what it is ALL about. Oil discussions. If people don't discuss differences and what not, there is no point in having a forum.
By the time it was brought up to me the time window for edit was closed.The Castrol and NAPA cold viscosities look off by a factor of about 100.
I mean since that's what it is ALL about.
I also believe that HTHS is important, but you do get a minimum value from the approvals. For example on my new Tiguan I'm going to use Mobil 1 ESP 5W-30 since it has VW 504 00 approval with an HTHS minimum of 3.5. I don't need a separate chart to tell me that.There are two things missing in the tables that I look at to help choose between oils with the same viscosity rating: 1) HTHS viscosity and 2) Noack. I typically choose oils that have higher HTHS and lower Noack if the formulation is similar. Also like Moly in there. I went through this exercise a while back and went with Valvoline Advanced when I started looking and comparing.
Who are those people infatuated with NOACK?I also believe that HTHS is important, but you do get a minimum value from the approvals. For example on my new Tiguan I'm going to use Mobil 1 ESP 5W-30 since it has VW 504 00 approval with an HTHS minimum of 3.5. I don't need a separate chart to tell me that.
As far as Noack goes, some people are quite infatuated with that but I struggle to find any relative importance outside of the approval requirement.
