What If : Tested engine : 6 cylinder engine holding 4 quarts of oil (no make-up) and having 20 k on the car and 10 k on this oil had on analysis:
20 lead
20 iron
20 chromium
20 tin
20 copper
20 aluminum
If the oil was replaced after each 10 k interval to 100 k total car miles what would be the theoretical wear in mm of the engine bearings. Say each analysis of 10 k miles gave the same results. Say there were 4 total, all the same size. I know there is lacking information but still, what are we looking at in real wear possibilities. Does this give us a range? Is it just nanometers - in which case who cares?
What are your thoughts of wear numbers to real, measurable wear after 100 k mile on the car having consistently elevated numbers as above.
aehaas
20 lead
20 iron
20 chromium
20 tin
20 copper
20 aluminum
aehaas
