This is my daily driver, but it doesn't go very far each day as you can see from the miles on unit. I purchased new and took delivery on 1/2/2013. First change after factory fill was dealer bulk, which I was told is Kendall semi-synthetic, and used Nissan filter. This report is for the second oil change for the vehicle. Filter used was Nissan brand from dealer. Refilled with same oil and used a Fram Toughguard filter.
Blackstone comments: High copper and silicon are just lingering from wear-in, so they
should improve next time, even with more miles, and the oil is in good shape physically, with a TBN of 3.0.
Averages are based on ~5,700 miles of oil use, so try 6,000 miles on your next run. If it looks good, you
could go even longer after that. Nice report here!
Code:
MI on Oil 4,213 MI on Unit 10,240 Sample Date 06/28/14 Make Up Oil Added 0 quarts Oil Type Pennzoil Platinum 5W30 Universal Avgs ALUMINUM 6 4 CHROMIUM 1 1 IRON 18 11 COPPER 23 7 LEAD 1 3 TIN 0 1 MOLYBDENUM 56 75 NICKEL 0 0 MANGANESE 2 1 SILVER 0 0 TITANIUM 0 1 POTASSIUM 3 2 BORON 4 45 SILICON 31 17 SODIUM 4 45 CALCIUM 2290 2191 MAGNESIUM 11 179 PHOSPHORUS 600 685 ZINC 699 807 BARIUM 1 0 SUS Viscosity @ 210°F 56.6 cSt Viscosity @ 100°C 9.25 Flashpoint in °F 405 Fuel % <0.5 Antifreeze % 0.0 Water % 0.0 Insolubles 0.1 TBN 3.0
