Hello Fellow BISTOG:
I have a '05 Toyota Rav4 and a '06 Toyota Camry both with the 2AZ-FE 4 cylinder engine. I've been putting PP 5W-30 for the past 3 oil changes on both Toyota. The owner's manual calls for 4 quarts of oil with filter change. However, when I drain the oil, both cars are always 1/2 quart short. Is it normal for Toyota engines to burn a little oil while running synthetic? Thanks for your help!
-ttvr4
-ttvr4
