quote:
Diesel Lube Oil Extender replaces the additives in diesel engine oil to provide the extra protection required between engine oil changes.
Replaces the detergents, friction-modifiers and anti-wear additives depleted between extended oil changes
Provides extra protection during high-temperature, high-load operations
Protects against thermal and viscosity breakdown
Reduces valve and piston-ring sticking - decreases oil consumption
Disperses soot to reduce sludge formation in engine oil
Reduces engine wear during cold starts
Does not contain any alcohol of any kind
One 32-ounce (one quart) container of Diesel Lube Oil Extender replaces one quart of engine oil and is capable of treating up to 15-quart crankcase capacity.
One 96-ounce (three quarts) container of Diesel Lube Oil Extender replaces three quarts of engine oil and is capable of treating up to 45-quart crankcase capacity.
Add Diesel Lube Oil Extender at oil change or when oil level is down, as make-up oil.
