My 03 L300 has developed a power steering pump whine when cold. The noise lasts for 10-40 seconds depending on how cold it is. The car has 70k miles on it and I think it is time to change the fluid. What GM approved PS fluids would work best? Is going to a synthetic fluid worth it.
The pump has also developed a slight whine when warm at idle, the noise goes away above 1500 rpm. I am thinking the fluid is old, and or some form of cavitation caused air to get trapped in the pump. When you turn against the lock it whines pretty good. It does not sound like a bearing noise, more like when you are low on PS fluid, although the level is correct. I am just hoping the old fluid is bad, as I can never really remember ever having PS pump issues on a GM car. And the pump for this car is expensive.
Any ideas or suggestions would be appreciated.
