Every once in awhile I see these things in stores or on TV. "Guaranteeeed" to save you money! Make your motors run cooler, last longer, reduce your electricity bill 15-45% OR MORE!!! ACT NOW!!! SAVE THE PLANET BEFORE IT'S TOO LATE!!!!
Bravo Sierra.....
The majority of people don't understand electricity much less power factor (PF), AC vs DC power, real vs. imaginary power or even how an electric motor works.
The short answer is: Don't ever fall for this! If you want to save energy, follow the old rules:
"There's a Sucker Born Every Minute" - P.T. Barnum
Don't be a Sucker!
- Turn off lights when not in use.
- Shut the (outside) door to keep the cold or warm air in.
- Don't stand in front of the 'frig with the door open, trying to decide what your looking for.
- Turn off the TV when not in use.
- Buy a more efficient pool pump (if applicable)
- Seal the ductwork in your house
- Clean both AirCon evaporator & condensor coils once a year.
Quote:
More and more often lately, we see glowing reports on TV and in the popular press about the latest inventor who's managed to come up with a device that will save you anything from 25 to 35% on your electricity bill. We should not be alarmed (apparently) to discover that most of the 'inventors' of these revolutionary products seem to be uneducated and are unattached to any research arm of a university or similar. Almost all advertised 'power savers' on the Net are a scam - 100% of plug-in 'power savers' are a scam - no exceptions.
When people buy these things, they may well be 100% convinced that they are saving money and their bills are lower. There are likely to be three effects that make it appear that they are getting cheaper power. Firstly, there's the well known and documented placebo effect, where the belief is so strong that the user will be utterly convinced that they are saving money - even if the reverse is true. Secondly, having installed the device and wanting to see lower usage, the owner will change usage habits - probably without realising they've done so. Finally, no-one wants to look like a fool, so they'll tell you it works to save face. If it didn't work, they've been taken for a ride and no-one likes to admit they've been scammed.
