Girlfriend’s secondhand Husqvarna mower that she bought for $40 from a friend. Used only once by her (last year) and put away when it didn’t work well. It has a 190cc Briggs & Stratton 725EX series engine.
I decided to take a look at it earlier this week to see what the issue might be. First things first: check and change the oil.
Out: A few drops of the blackest oil I’ve ever seen. Oh no. This isn’t going to be good.
In: SuperTech full syn 5w-30
I ran it for a few minutes, then dumped the fresh oil out. Dark, silvery, sparkly sadness. Oof. I went through a few more cycles of filling, running, and draining, and the sparkles continued. I finally decided to fill the crankcase one last time, use the mower, and let the chips fall where they may. Sure enough, it seizes frequently out in the yard.
Time for a new mower!
The original filter, you think?New-to-me 2015 Ariens Zoom 42, Kohler 7000.
Out: Unknown oil, standard black Kohler filter.
In: Mobil 1 0w-40 FS (SP), Fram Endurance FE3614.
No, last service Sharpie reports April 2021.The original filter, you think?
3247 hours? Is that the original engine? If so, that’s impressive.Exmark Laser Z 60" - 3247 hours - Kohler Command V-Twin 27hp
Out: Rotella 15w40, Wix 51348
In: Rotella T5 10w30, Purolator PureOne PL10241
After digging into earlier posts I determined that it was 59 hours on the oil and 99 hours on the filter.John Deere D140 lawn tractor. 274 hours and nine seasons on the machine.
Oil is oil !Free 15HP KingCraft Generator,
Out: Something nasty looking, maybe the original 30wt/10W-30 that was in the box when it was new? Yuck.
In: SP Mobil 1 Euro FS 0W-40
You're absolutely right the fact that there was oil in it is already a great thingOil is oil !
How dirty was that oil?After digging into earlier posts I determined that it was 59 hours on the oil and 99 hours on the filter.
I believe the original engine was replaced with this one around 1000 hours.3247 hours? Is that the original engine? If so, that’s impressive.
2,200 hours is pretty good.I believe the original engine was replaced with this one around 1000 hours.
Yep oil changed every 100-150 hours. Original hydro pumps, I did a change with Valvoline Synthetic 20w50 and Exmark hydro filter. Machine is still nice and solid, not much play in anything. The 27hp Kohler Command doesn't even smoke or use a noticeable amount of oil between changes.2,200 hours is pretty good.
I’ve always done yearly or 100 hours on an oil changes.Yep oil changed every 100-150 hours. Original hydro pumps, I did a change with Valvoline Synthetic 20w50 and Exmark hydro filter. Machine is still nice and solid, not much play in anything. The 27hp Kohler Command doesn't even smoke or use a noticeable amount of oil between changes.
